My computer is working fast on almost everything except when playing 3D games. So I need to run MW3 to reach the 16-25 fps. I am getting confused now if I will upgrade the graphics card or my video card so my computer will work well with 3D games. How can RAM helps on the speed of my PC? Please send me some advices on how I can improve my computer speed especially when playing 3D games. And also, how can I check on the version of my video and graphics card so I can know what to buy if I will change it. Thank you.
lee hung
75 points
Graphics or Video Card: Which to upgrade?
You must be having a good quality video card to play games on your computer. At first you should be sure that the graphics card is compatible with your motherboard. Otherwise you won’t get good results. You should collect the information about your processor, motherboard for connect a good quality graphics card with your computer.
After you connect to the graphics card can be installed on the hardware and software for which you provided, i hope that you will find the CD with your hardware. After you have completed everything correctly, the computer will restart. Would you like to play games and do not expect graphics problems.
(You Confirm System check, My Computer, System Properties, Hardware tools, Device Manager, Driver/Details/General, Driver Details/ Update Driver, then confirm your updates )
You must be having a good quality video card to play games on your computer. At first you should be ensure that the graphics card is compatible with your motherboard. Otherwise you won’t get good results. You should collect the information about your processor, motherboard for connect a good quality graphics card with your computer.
Thanks
Thank you so much Rumen for your solution. i noted everything you said about my 3D query. Your solution is very helpful. thank you again. Thanks TechyV!
