Graphics Software installing Problem in Laptop
I have download a trial copy of adobe illustrator. It's not installing.But my Laptop has the all requirements.What can I do regards this problem?
A graphics driver is a piece of software that tells your video card hardware how to function. In Laptop PC manufacturer that my use a variety of different video cards in its laptop machines. Laptop manufacturers often integrate the video card into the system board. Integrated graphics or onboard graphics don't produce the same quality of video as do separate graphics adapters, but are comparatively much cheaper. Outdated or corrupt graphics drivers can cause a system to exhibit graphics failure. The operating system communicates with the graphics adapter through its driver. Updating the drivers can repair display errors.
If you say your computer already met all the system requirements of Adobe Illustrator then it is probably a problem with the installer you downloaded. This is very common especially if the installer was acquired from a different website and not from the software’s official home page. To make sure your installer works, visit your product’s home page.
I’m not sure what version of Adobe Illustrator you have but its worth to try downloading and installing Adobe Illustrator CC. This version doesn’t require a fast processor and will even work on a Pentium 4 or AMD Athlon 64 processor. Another thing about the installer you downloaded, I’m not sure if you have already checked but processors have variations between 32-bit and 64-bit.
Like with Adobe Illustrator CC, it will not run if your processor is 32-bit. It will only work if your computer is running on a 64-bit processor so you need to check if the problem is in the version or architecture of your processor. Adobe Illustrator CC works on Windows 7 Service Pack 1, Windows 8, and Windows 8.1.
For Mac users, it runs on Mac OS X 10.6.8 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, and 10.9 Mavericks.
