Grid Paint apps for Linux in free of cost
Where should I get Grid Paint apps for Linux in free of cost. I need a software as that of Paint-By-Grids Software that runs on Windows 95, 98, 2000 and XP. If Grid Paint apps for Linux is available for free, please do the needful for sending me the link that will download the software.
Answered By 50 points N/A #167825
Hello , James C Montes
Hope you are fine. I think I can give you a solution. So don’t worry. You can use Paint- by- Grids.You to quickly grid any digital photo, web image, or scanned image by using this software.
At first open any JPEG or BMP file
And choose a canvas size
And then the application will automatically apply grid lines to the image, and thus will produce a full-size mock-up.
Paint – by – Grids
You can also use Grid Maker 2.0 .To grab it click below
Grid Maker 2.0
Hope you will get your answer.
