Guest Additions installation fails in Windows XP 64 guest
Posted on - 08/11/2014
While the installation of an addition for Virtual Box this error appeared and the Try Again button is not helping and if I press Skip another error appears. Can anyone help me with this error ? What I have missed ? The installer is downloaded from a trusted source and is compatible with my Window XP (x64).
Thank you !
![](https://www.techyv.com/sites/default/filesx/users/Techyv-Images/Guest-Additions-installation-fails-in-Windows-XP-64-guest.jpeg)
Sun Xvm VirtualBOX Guest Additions 2.0.0.S.
Error opening file for writing:
C:WINDOWSSysnativedriversvBoxSF.sys
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file
