Guidance on how to trac vpn logins?
Hi Experts,
I am having a proxy server which is run on Linux. I need help in how to trac vpn logins?
I tried on using command prompt. But I need the exact commands.
Lark Yency
Hi Experts,
Lark Yency
Hi there,Â
I am not that good at this area, but I honestly wanted to help you so I searched around and I found a couple of websites that may help you out.
Read it, I think that people suggest a software which you can use to solve your problem.
Still it`s better if you do it manually, it should be an easy task since you are good at what you do.
1. Monitor Internet Usage of VPN Users
3. Testing and Tracking VPN ConnectionsÂ
Hope this helps,Â
Regards,Â
