Guidance required for android ram expanding
HELLO !
I am using android mobile and I heard about android ram expanding, can anyone explain me how it works and kindly also mentioned me the procedure as how to install this and what are the steps ?
HELLO !
Hi
If you want to increase your RAM in your android phone nothing much to do. Just put a high GB sd card like 32 GB card and can use it as a RAM . you can down load a ROM from internet Google and install it in your Phone. Go to Swapper for root from Google play, down load and install .Then link up with your sd card and it will work as you want for RAM.
Thanks
On Android phone, The Phones Ram has a small memory and it is not enough to play a high quality games or open a lot of applications at a time. So, you must extend or boost your RAM.
You can use the Smart RAM Booster apps to increase your RAM. You can download it from here. It is free to use.
You can also use the Roehsoft RAM-Expander apps. But, you must pay $8.98 to use it. You can download it from here.
You can use your memory card as a RAM. So, at first put your memory card in the phone.
Then download a Swapper app from Google play store.
Now enjoy it.
