carlsnel
10 points
Posted on - 08/07/2011
Hi, I need some help on what is the best Casing Side Panel Fan, my fan here is a little bit noisy. I already bought twice and it will only last for 3 month and it will get noisy again, changing fan every 3 months is so costly.
Thanks a lot.
Guide on buying computer cooling fan
Fan is very essential component of the computer or else the computer might get overheated and may cause some hardware and performance problems,try to buy delta fans because they are good heavy duty fans,and if you can afford water cooling system for your pc ,please do buy that it can get core temperature as low by 20 c. But if you live in cold region and you are noticing no performance problems by the removal of fan then its just fine without it.
But you have to do it keeping your computer status in your mind. To closely log temperature and memory usage i would suggest you using program known as cupid it is totally freeware and helps a lot.
Genebraldo Regio. Hi,Â
First check if the screw is loose. Then Try to use Quality Brand item. It’s more trustworthy and durable than time.
Use Ball Bearing Fans for long time usage and many branded side fans on ebay for cheap price, Try it.Â
Good luck
