Guide on DVD sharing for Mac to watch movies
Hi! Is there a MAC user here? Does it support DVD sharing for Mac to watch movies? Or we have to set up some software to be able to do so. Any leads will be appreciated. Thanks
Hi Dudley,
Mac supports DVD sharing, but you’ve to change some option. On the other hand, there is some ‘ SuperDrive Add-on’ but it’ll cost you $70 to $80. Just follow these steps below:
1. Click on the ‘DVD or CD Sharing’ feature from the sharing option of system preference.
2. Open Mac finder and connect to the remote disc. Click on it.
3. Select a computer and click ‘Ask to use’.
After the permission, you’ll be able to explore the disc.
Good Luck.
