Hi guys,
On my lap I have installed windows 7 professional version.Â
When I am installing Zeus on windows 7 I got some errors.Â
Please can you guide me about the installation Zeus windows 7 on my Lap?
Guide me about the installation Zeus windows 7 on my Lap
Hello Goldman Diane,
It is good if you want to play Zeus on Windows 7 with no problems to install Poseidon expansion as well since it makes Zeus playable on Windows 7
Do you try installing widescreen mode?
Zeus Installation on Win 7
For earlier version of Windows the components of the game where installed in C:program fileszeusfolder, but on Windows 7 the installer follows the Microsoft UAC model. On Windows 7 the folder C:program filesfolder is locked by UAC (installer uses different approach).
What you need to do: Create C:program fileszeusfolder, copy the read only components into the C:program fileszeusfolder then copy red/write components into the C:programdataXidiconezeusfolder
To check that the installation ran successfully make sure C:programdataXidiconezeusfolder exist and contains 6 folders. When you run for first time it will complete the installation by doing the following: Create C:UsersCurrentusersAppdataRoamingXidiconeZeus user folder then copy the read/write components from the C:ProgramdataXidiconeZeus intermediate folder to the C:UserCurrentuserAppdataRoamingXidiconeZeus user folder.Â
CPU: Pentium
CPU Speed:Â 166MHz
RAM:Â 32MB
Hard Drive Space:Â 450MB
CD Drive Speed:Â 4X
Video RAM in MB:Â 2MB
Graphics Resolution(s): 800×600
Good luck with installation.
Regards!
Nathan H Underwood
