Guide On How To Perform A Clean Boot In Windows
I need to know how to perform a clean boot in Windows as I am using a Windows PC and I need to do a clean boot for my task but I am unable to do so. Help me guys.
To do a clean boot on your Windows PC-
This how you do a clean boot.
First up, you don’t do a clean boot for no reason. This is only done when you need to troubleshoot a problem or to isolate the cause of a certain issue. To do a clean boot, click “Start,” “All Programs,” “Accessories” then right-click “Command Prompt” and select “Run as administrator.” In the command prompt window, type without quotes “msconfig” then hit Enter.
In System Configuration Utility window under “General” tab, select “Selective Startup” then uncheck “Load Startup Items.”
Next, select “Services” tab then click “Disable All.” Click “OK” then restart the computer.
After booting the computer, you are now in a clean boot environment. When you are finished troubleshooting, run the “msconfig” command again and select “Normal Startup” in “General” tab to boot the computer normally.
