Guide To HP Elitebook 2570p MSATA Installation
I want to use an mSATA solid state drive in my HP EliteBook 2570p laptop? Will it be safe to use, and any other things I should keep in mind?
Answered By 40 points N/A #320146
mSata is a solid state drive or SSD, and it has a smaller form factor than a normal SSD. They were designed to be used with energy efficient devices like tablets, laptops. Sadly, HP Elitebook 2570p does not have a port that can support it. Also, you cannot update the hardware of the ports, so it’s practically impossible for you to connect the SSD. Buy a normal drive for now.
