Guidelines on “how to install map guide 2011”
Asked By 7060 points N/A Posted on -
We’re in a test phase and want to have guidelines on how to install map guide 2011 in order to avoid virtual directories and the application pool settings errors. Any help would be highly appreciated. Thanks !
Answered By 0 points N/A #195030
You did not mention which OS you use on your PC. I have a pdf file here with detailed information on how to install the map guide. I hope it is enough to answer your question.  You need the two separate components that make up Map Guide Open Source, the Map Guide Server and the Map Guide Web Server Extensions. They are very long, and I think it will better for you to visit these links to download them: http://mapguide.osgeo.org/files/mapguide/docs/InstallConfigureMgOpenSourceOnWindows.pdf
Best of luck.
