Olivia Aust
10 points
Posted on - 10/20/2012
The problem is with NVIDIA graphics driver. While playing a game it has stopped working. Sometimes it is showing the black screen and sometimes for a few moments playing the game. Then it stops throwing the error message asunder. Have you any idea for the issue?
The current configuration of my machine is i7 860, 2.8 GHZ with GTX 560 Ti 1 GB RAMS.
Please help.
Guild Wars 2
Guild Wars 2 has encountered an unrecoverable graphics driver error and must terminate.
Click on the URL below to open a web page with more information.
https://help.guildwars2.com/hc/en-us
Hello Olivia,
You will need to try going to your Document, and then go to the Guild Wars2 Folder. In there, you should check for ArenaNet.txt. You will need to open it and then check the crash log. Also, you can go ahead and then rename the Local.dat to Local-Backup.dat.
Nicke
Hi Olivia Aust,
You must update your graphic driver. Check the readme file from your game folder so that you may know the exactly the specification requirements of your games. Most of the games today required a separate video card to run smoothly.
