Ryan Abate
30 points
Posted on - 08/24/2012
Hi, yesterday when I tried to transfer the process definition file via eclipse, I got the following error message. Both the guvnor and the designer are running under the same container and for logon they are using anonymous method without username and password. What does this error message mean?
Guvnor Repository Error
Reason:
Premature end of file.
Guvnor repository error:premature end of file.
Hallo Ryan,
Have you tried changing the logon procedure, so that instead of using anonymous method that does not involve username and passwords you use custom username and passwords? If you haven't tried that yet I will suggest that you do so and see if it will help resolve the issue.
Otherwise the application could be corrupt. If you have been using it before without having issues until then you it is possible that the application has some issues, a case that may need you to reinstall the application to resolve the bugs. It could also be the file that you are trying to transfer that is causing issues, and therefore you will need to retry using another file and see the response you will get.
Carl
