I have gone through the specification of Haier W718 IP67 Smart Phone Android 4.0 which costs around 160$. Is that cost effective, Is there any other phones apart from Haier phones have this specification and which will have low cost comparatively as that of Haier W718 IP67 Smart Phone Android 4.0.
Haier Phones : W718 IP67 Smart Phone Android 4.0
Looking at the specifications for – "Haier W718 IP67 Smart Phone Android 4.0" this phone has Android 4.0 and a 4.0 Inch screen. Considering the cost perspective, there is one alternative you could try. That is: "Samsung Galaxy Note II (GT-N7100)" In fact Some version of Samsung Galaxy Note II are much cheaper than Haier W718, i.e. you buy from a correct place. You can find its price range on different websites. Another thing is that it has Android 4.1 and a bigger screen of 5.3 inches. You could check other low cost options here.
I would like you to go for Samsung or HTC rather than Haier W718 IP67. If you are able to spend few more bucks in this range then you can go for Samsung or HTC. This Haier model is not effective at its mentioned cost, you can get some problems from this phone. I would like you to go for Samsung Galaxy Note in this specifications.
Hope this helps
