Help about Free skins OWA downloads please
Hello,your question is, Can you advise about free skins owa download please ? My answer is yes. You can done this simply by download a software which is called Xbox Theme for Outlook Web Access (owa). I think this will help you to solve your problem. Here is the owa theme sofwere link- http://download.cnet.com/Xbox-Theme-for-Outlook-Web-Access/3000-10248_4-10735376.html . Just go there and press the button Download Now and your download will start.
 Thanks
Eaana Albert
Yes you can get the skins and themes for OWA also known as Outlook Web App from Microsoft. This will enable you customize your application to your preferences.
I might also need to warn you that installing these themes on Outlook may be technical and tasking
Themes can be found at https://userstyles.org/styles/78838/outlook-web-app-owa-olive
