Blake Burke
10 points
Posted on - 04/11/2012
I want to replace my old cellphone with a smartphone. Can you recommend 3-5 units that have long battery life that can last more than 24 hours on a single battery charge? Not iPhone please.
Handsets with long battery life, more than 24 hours
I have been planning on purchasing a smart phone myself and I have some researching on my own. So far, A really cool Smartphone with the longest battery life would be Sony Ericsson Xperia Play with a battery life of 10 hours. Aside from a really good battery life, it prides itself on fast performance and some cool display for gaming fanatics. Unfortunately, I haven’t found a Smartphone yet that can last for more than a day on a single battery charge – But let’s not forget the 10 hours last for good whole day of use – it depends on how much you use the phone. It can last for 10 hours or more.
Though I’m not sure about the 24-hour battery life part but if you want to know the phones with best battery life, according to phoneArena.com, Samsung Galaxy S7 edge is among the Smartphones with the best battery performance for the year 2016. Samsung Galaxy S7 edge is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies.
It was announced to the public on February 2016 and released on March 2016. It measures 150.9 x 72.6 x 7.7 millimeters and weighs 157 grams. The back panel is built with Corning Gorilla Glass 4 and available in single SIM and dual SIM models using nano-SIM card. It has IP68 certification making it dust proof and water proof up to 1.5 meters for 30 minutes.
It supports Samsung Pay which is certified for Visa and MasterCard. It has Super AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 4 featuring always-on display, TouchWiz UI, and curved edge screen.
It runs on Android 6.0 Marshmallow upgradable to Android 7.0 Nougat powered by Qualcomm MSM8996 Snapdragon 820 chipset for the G9350 model and Exynos 8890 Octa chipset for the G935FD, G935F, and G935W8 models, Quad Core (2×2.15 GHz Kryo & 2×1.6 GHz Kryo) processor for the G9350 model and Octa Core (4×2.3 GHz Mongoose & 4×1.6 GHz Cortex-A53) processor for the G935FD, G935F, and G935W8 models, and Adreno 530 GPU for the G9350 model and Mali-T880 MP12 GPU for the G935FD, G935F, and G935W8 models.
It supports microSD expandable up to 256 GB. It runs on 4 GB RAM with internal storage available in 32 GB, 64 GB, and 128 GB capacities. The primary camera supports 12 megapixels with f/1.7, 26mm, LED flash, phase detection autofocus, and OIS featuring 1/2.5″ sensor size, 1.4 µm pixel size, touch focus, face and smile detection, geo-tagging, auto HDR, panorama, and simultaneous 4K video and 9-megapixel image recording and can record video in 2160p at 30 fps, 1080p at 60 fps, and 720p at 240 fps with HDR and dual-video rec.
The secondary camera supports 5 megapixels with 1/4.1″ sensor size, 1.34 µm pixel size, f/1.7, 22mm, auto HDR, and dual video call. It has 3.5-millimeter jack featuring 24-bit/192kHz audio and active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.2 with A2DP, LE, and aptX support; GPS with A-GPS, GLONASS, and BDS support; NFC; and microUSB 2.0 USB Host.
It doesn’t have stereo FM radio. It has built-in front-mounted fingerprint, barometer, heart rate, SpO2, accelerometer, gyro, proximity, and compass sensors. The preinstalled web browser supports HTML5. Java is not supported. It runs on non-removable Li-Ion 3600 mAh battery with talk time up to 27 hours on 3G. It is available in pink gold, black pearl, black, white, gold, silver, and coral blue colors.
