I have windows 7 installed and recently I added handwriting fonts open office to my collection but whenever I try to use those fonts, I can’t understand what is written. Does anybody know why the fonts are not working properly? Any kind of help would be appreciated.
Handwriting fonts openoffice are not working in Windows 7.
Hello Kenneth Nickersonee,
You have installed windows 7 now you have to reinstall Microsoft office. To solve the problem you have to take some step those are follows.
1. Uninstall your Microsoft office.
2. Install you Microsoft office.
3. If not worked you have to download the handwriting font.
4. Download font from the link: http://www.fontspace.com/category/handwriting .
5. Copy and paste the font in windows font’s folder.
Now you can write in handwriting font.
You are having some font problems in your pc where windows 7 is installed. In windows 7 font setting are a bit different. So, that makes some problem installing fonts properly. Most probably, your handwriting font file is big than normal size. Or, the file is corrupted. If so, you had not properly installed them. Look for solution in the video.
- www.youtube.com/watch?v=-YvRa2u58nI
You can also go through this whole thing and make a sense. Then, may be you can fix the problem correctly. Please read the instructions in the following suggestions:
Hope these helped you.
