Hi all,
I installed Handy Cafe 3.3.21 for my wifi network computer. When I plan to uninstall that I can't uninstall Handy Cafe smoothly. Is there any application that will work as Handy Cafe remover uninstaller. Handy Cafe is creating a big trouble for me. Also do let me know, why Handy Cafe can't be uninstalled smoothly ?
Kristoper T Stark
Handy Cafe remover uninstaller application
Hi Kristopher,
You can uninstall the Handy cafe remover by using the special uninstaller software
The steps to uninstall the Handy cafe software are as follows:
1) Download the software from official Handy Cafe website
2) Install the software in the system by following the installation wizard
3) Open the uninstall tool, select 'Handy Cafe' from the list
4) Click 'Run Installer' button
5) Click 'Yes' to confirm the uninstall
6) Complete the standard uninstall process and Click 'Scan Leftovers' to remove all leftover data
7) Click 'OK' to finish the removal, restart the system
Hello, This is how to delete Handy cafe. I've got two suggestions for you.
A. When you are using Windows XP, then go to Start -> Run -> msconfig. On the startup tab. Uncheck hndyc then restart the computer.
B. The following are some simple instructions you could do.
1. Open your system case or casing of your computer.
2. Remove the SATA HARD DISK DRIVE or IDE HARD DISK DRIVE or simply remove your hard Disk. 3. Open one good computer I mean who don’t experiencing that same problem.
4. Install or put the hard disk on it after that.
5. Boot your computer.
6. Locate the hard disk drive that you have install on it.
7 And finally locate the installation directory
8.Delete the Folder just simply hit “Shift DELETE” and hit okay.<
9.remove that hard disk and install it back on your computer. And BOOT
10. Your DONE!!!
You could also use an installer like the one here
If you installed HandyCafe for your small home Wi-Fi network but now you are unable to uninstall it when you want to remove it, try uninstalling it with third-party software. One reason why it is unable to uninstall is when it is incomplete. This can happen when the program installed incorrectly. To make sure the program will uninstall, reinstall it without uninstalling the program.
To do this, run the installer and install over the existing installation. You can also download the latest HandyCafe to update the program. Next, download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select HandyCafe among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo Uninstaller then restart the computer if it is needed.
