Hanging Problem In Mobile Phones
I am not able to use my mobile phone comfortably; it’s hanging a lot. How do I stop my phone from hanging?
Each mobile phone has some memory stored until which you can download. Overloading might result in hanging up of mobile phones. So, some of the things you should do are, you should minimize the number of applications running in the background. Always keep on upgrading your applications as it helps to occupy less memory.
Switch off your mobile phones in a while, which helps to refresh your mobile and remove all unnecessary data. Store your applications from internal to your external memory. Delete unnecessary apps and data that you don’t need. It can help you remove your hang-ups.
Notifications
