Hard disk failure what is the problem
Hi Techyv,
Can you please help me, In boot startup, I had this error "Disk Boot Failure, Insert System Disk and Press Enter".
What seem to be the problem? Do I need to change my old ones?
Hi Techyv,
Hi Stella,
The error message occur when the system is not detected a hard disk on your computer. To make it sure try to remove your hard disk and this is what you can see on the command prompt. All you have to do first is to restart your system repeatedly until the windows appeared on the screen, or until the windows booth on your screen. If this procedure didn't work then you should proceed to the next step but to unplug/plug your hard disk and observe if the hard disk is detected on the system. Lastly if there is still an error then the problem is really the hard disk so replace it and i'm sure it will work. You should follow this following steps to troubleshot your hard disk, this is commonly happens in an old PC, this is rarely seen if you have a new PC.
Thanks,
Tony Stevenson
Here is how to fix the disk boot failure problem:
-Clair Charles
