Hard disk image creator download freeware
I'm looking for a program that can create, edit, read a hard disk image and can inject files into an existing image.  Is there a freeware hard disk image creator download that also supports NTFS and Linux EXT2FS/EXT3FS?  I'm on Windows Vista 64 bit.  Thanks.
Answered By 0 points N/A #180094
Dear Darreno Marcy,
If you are looking for a program that can create, edit, read a hard disk image, and can inject files into an existing image and also support NTFS, I recommend to you to try the Acronis® Disk Director which contains several functions that far exceeds what you are asking for. Also, as another solution, you can try to mount using DTLite which is free and very light on PC.
Best regards,
Don Muench
