Mark E Ward
30 points
Posted on - 11/25/2013
Hi friends,
I am using Hitachi Touro Mobile 2.5 Inch 500 GB External Hard Disk. It crashed a few days ago. I saved all my personal details in that disk. Please tell me about any online free software for hard disk repair tools Hitachi drive. Your information will be very valuable for me.
Thanks in Advance,
Mark E Ward
Hard disk repair tools Hitachi
Hi Mark,
There are several disk repair tools mentioned below:
1) Disk Checker:
a) It is a hard drive monitoring/repairing tool for Windows
b) It locates files that contains errors
c) It is possible to create images in array of formats
d) Download the software from the disk checker official website
2) Hard Disk Wipe Tool:
a) It is a free utility for low level hard disk erasing
b) It supports LBA-48 drives
c) Download the software from the hard disk official website
3) HD Doctor for Hitachi:
a) It is manufactured to handle Hitachi hard drive corruption, repair bad sectors
b) It is freeware utility and supports different Hitachi disk drives
c) Download the software from the HD Doctor official website
If your hard drive crashed and you need to fix the error to access your files again, you can use PC Tools to check and fix errors. Download PC Tools Performance Toolkit and install. Once installed, start PC Tools then go to “Recovery” tab and click “Repair Drives.” On the next screen, select the drive you want to check.
From the options, select “Surface Scan” and check “Perform on reboot.” Click “Start” then “Continue.” Exit PC Tools then restart the computer to begin the check. The checking will be quite long depending on the size of the drive and the extent of the problem. If bad sectors were found, try repeating the scan a second time.
Bad sectors are normal for hard drives like IDE and SATA and usually appear as the drive gets old. If bad sectors appear everywhere on the drive and the drive is quite old, it means you need to replace the hard drive with a new one.
