Hard Drive is Corrupted and Windows won’t load
Asked By 100 points N/A Posted on -
My problem is always occur I just have installed Windows 7 Ultimate a Clean installation but a few days Problem is always en counter that windows won't load up. What should I do with this? What I thought is maybe my Hard Drive, but problem I can't afford from now to buy new one. so help me please…
Best Answer by mandeep002
Answered By 0 points N/A #82279
Basically windows is in HDD so you have to check the hdd in service Centre whether it contains errors or not afterwards you can reinstall or change hdd. Sometimes hard disk booting sector is too weak because of this it cannot load out the windows. whether it is healthy or not. So please go through the boot sector errors check.
Answered By 5 points N/A #82281
Have u checked for any virus in your system, If not than do complete scan of your drive. If no virus found, then check your system configuration once. To run Windows & it requires at least 512 mb RAM and Intel Pentium 4 Processor with 3.2 GHz. If your system has lower configuration to this, than I suggest install windows XP. If configuration is OK. Then might be your hard disk having some problem, then u need to checked it service center.
