A hard drive detection tool to use in fixing errors
Dear experts,
My hard drive has encountered a warning message, all of a sudden, it just crash. Do you know a hard drive crash detection tool to use? Thank you!
Dear experts,
Hi Jerold,
It’s really unfortunate. Before using a tool for hard dive crash I want to share some experience with you. May be you’ll find this helpful. If you seriously follow the symptoms of hard drive then you can easily asses the HDD crash without a tool. Just notice few things as strange noises, disk error message, disappearing data etc. These are the most common symptoms of hard drive crash. Or you can download Active Smart tool from this site:
http://activesmart2.software.informer.com/download/
You’ll have to download the .exe file from here and install it.
Good Luck.
Dear Jerold Kramer,
It is so sad that your hard drive is having problems.
There is a lot of software that can check the hard disk for errors and possible problems.
I suggest you to use Norton's Disk Doctor for this.
This software will fully protect against bad sectors, bad clusters, partition table errors and other problems.
You can download this software from this link.
I hope it will help you.
Notifications
