Hard time installing ZENworks 11
Hi, the online software updater prompts on the SLE 10 SP3 64-bit during the installation of ZENworks 11, recommending for the installation of slesp3-jpackage-utils (norch).
However, on my several tries to install this package has failed and therefore, ZENworks 11 can never be installed into my system. How should this be done apart from the procedure that I have already attempted?
Any ideas will be much appreciated.
Error:
Dependency resolution Failed
Answered By 20 points N/A #145411
Hi Gerry, have you tried clicking "Resolved conflict via YaSTt" does it shows blank panel? No patches available? This is fixed in version 11.1 document ID  7008746.  Zenworks Configuration Management updated information and list of fixes which can found in https://www.novell.com/documentation/zenworks114/zen11_installation/?page=/documentation/zenworks114/zen11_installation/data/bookinfo.html#bookinfo
Workaround: at a command prompt, enter the command
rug in -y jpackage- utils .x86_84
An error like this means, there is software that needs to be installed first before you can installed successfully. Also you need to update the Zenworks imaging driver. Just read the TID 700876 for more details.
Please take note that upgrading 0f Zenworks 11.1  will be via media not with your system update.
