Hardware-assisted virtualization is disabled in Virtual PC
I'm trying to install Windows Virtual PC and XP mode to a Windows 7 computer. When configuring XP with Virtual PC, I encountered error from Windows. The error says, the hardware-assisted virtualization is disabled. I enabled it already in BIOS but I can still see the same error message. How should I fix this?
Unable to start Windows Virtual PC because hardware-assisted virtualization is disabled
Windows Virtual PC
Please follow these steps to enable hardware vithaltzation
– Restart the computer and enter BIOS setup.
– Search virtualization setting in BIOS and enable the setting.
– Save BIOS settings.
– Power off the computer. wait for few seconds and start the computer,
You can check your computer manufacturers manual for details on BIOS settings.
Learn more about BIOS virtualization settings
