Hardware configuration & display of Macbook pro.
Is the MacBook pro with retina display have the best resolution ever made?
What is its hardware configuration?
Hello! The MacBook Pro Retina Display is indeed has the best resolution ever. This Laptop has ultra high resolution screen which is maybe makes your text reading a little difficult. But then it can also give you advantage through its scaling modes. The retina MBP ships is pixel doubled configuration.
So you will have effective desktop resolution. This configuration is the best looking, though you don’t get more desktop space. But then Apple is exposed to predefined scaling options so you don’t need additional desktop space.  The performance of the Apple Mac has an upscaled rendering which gives a good performance and quality impact. But for the long run we will figure out how to manually add a zero scale don’t you think?
Heres the picture for you to check it out.
Apple’s MacBook Pro is available in two versions: the standard MacBook Pro, and the MacBook Pro with Retina display. And the MacBook Pro with Retina display is also available in two model sizes: the 13-inch MacBook Pro with Retina display with a screen resolution of 2560 x 1600, and the 15-inch MacBook Pro with Retina display with a screen resolution of 2880 x 1800. These two models are packed with extremely high amount of pixels to produce a very vivid display.
The 13-inch model is packed with over 4 million pixels while the 15-inch model is composed of over 5 million pixels. The density of the pixels are so high, your eyes won’t be able to recognize each pixels. The texts on the screen are so sharp it’s like you’re only browsing web pages, reading texts in a printed document, and or reading an email. The new Retina display reduces the glare by around 75% while still sustaining the amazing quality and color. See the changes in the images below:
MacBook Pro standard
