Hardware diagnostic software for free
My hardware is not functioning properly. I want a free hardware diagnostic software.
Do you know one?
Please help.
Thank You . .
Do you know one?
Please help.
Thank You . .
Before going through the hardware diagnostic tool, I would suggest that you rely on the tools provided by the manufacturer of your system
Secondly, you have not mentioned the operating system of your PC; the tools available are different for each operating system.
However, what we always recommend in such a case is the tool called “Ultimate Boot CD”. There are two basic versions of this software:
1. UBCD4W : The version of Cd which support the windows operating system, and is available.
1. UBCD: The Version of the program which supports the Linux / Ubuntu O/S, and is available from: http://ubcd.sourceforge.net/download.html
However, we also always recommend donating some amount, to the guys who performed and are performing the great job of creating and developing these tools.
PT
There are many software that you can use to diagnose the performance of your computer hardware, and most of them you can get for free from the internet. Some of them that I will recommend that you use are the following:
But you can still use the Windows diagnostics tool to check the performance of your computer system. All you need to is:
Regards
Thompson Locker
