Please help, I am trying to install Form Z but I'm having a problem with this error saying it doesn't recognize my hardware key. Here's the screenshot of the error:
formZ Installation.
Cannot find WIBU hardware key driver. Click OK to Install WIBU Driver, or Cancel to exit Installer.
Can anybody please provide me with a step-by-step instruction how to properly configure the application? Thank you.
Hardware Key is Not Recognized
I am also having the same problem and check the main website for the solution and got the idea what I was doing wrong in the first place. WIBU driver installation is very important before the installation and make sure that the virus software is disabled during software installation. Find the WIBU Driver Installer from WIBU folder of the form·Z CD. After driver installation run the WIBU-Key Control Panel from Start / Settings / Control Panels, port should be enabled in the Bios. Do not connect to the Internet if you get a Hardware Found Wizard and Windows will Install Software automatically. If for some reason Windows is not able to find the driver automatically, browse to C:/Windows / INF / wibukey.inf.
