Hardware networking question on Airport Base Station
Airport Express Base and The Airport Extreme have built in USB port from which you can use your printer. It doesn’t matter what is the type of your printer is. Before printing you have to make sure that you are already connected to the wireless router or either net cable. You can simple select your OS from the drop down menu by clicking the airport icon. The 2nd thing you have to do is to connect your system with the printer. If you have not installed any printer then your computer will not recognize the wireless printer. You can use to download the drivers or you can also use the CD came with the printer to install the drivers. Once you are connected with the printer you can easily print what you want to print by just selecting the ‘print’.
