I would like to know what damage overheating of the CPU of my tablet causes. I am currently using Samsung tablet with an Android version of 4.1 with a dual core processor speed of 2.5GHZ and I would also want to know as well if overheating can affect my tab performance. Thank you.
The harms caused by Central Processing Unit overheating
Overheated processor slows down and operates less efficiently. Using your device in a good environment can prevent this to some extent.
Overheating has a very diverse impact on the battery of a system. If your device gets overheated it can result in a chemical reaction between the ions in the battery resulting in reduction of battery life and time for getting it charged.
Motherboard consists of several wires and copper components transmitting electric charges throughout the system which results in reduction of efficiency and output of electric current which is very harmful for system performance.
