Has anyone tried to do list apps by the name Tik Tik
I was using my favorite to do list app, Astrid app for several years. But since Yahoo has acquired this apps, I was forced to search for an alternative apps. I found Todoist and Wunderlist. But my friend suggested TickTick which is not a well known one. Has anyone tried Tik Tik apps?
Answered By 590495 points N/A #136149
I guess what you mean is TickTick and not tiktik because there is no such thing. TickTick is a trouble-free to-do list cross-platform application. You can use it on your Android Smartphone, iOS device, the web, and as a Chrome extension. If you want to use it as a web browser extension, you need to have Google Chrome.
Visit TickTick Todo and Task List to install TickTick on your Google Chrome. If you want to use it on your Android phone, visit TickTick Todo and Task List for Android. The app is totally free but you have the option to upgrade it to Pro to be able to access the premium features.
With TickTick, you can synchronize all your tasks in all your devices. For easy access, you can also create a widget. The app also allows you to add a task using your email account as well as upload attachment to your tasks.
