Customizing my mouse pointer with animation cursor
When i turn off and turn on my PC I've to change again in mouse pointers, so i want to keep my own animation cursors on mouse pointers, so is there anyone can help me in that please.
Changing mouse cursor is fun, you'll get to personalized the mouse pointer to look nice. It is also helpful to have your own personalized mouse cursor for clear view. Some application needs to have this because of it's usage, specially if you're on games.
I'll provide you the steps to do so, here's how; > Go to Start, Open Control Panel > Click twice on mouse icon > Then on Mouse properties, click on Pointers tab > On Pointer click, the down arrow on the Scheme and select the cursor you want This should let you change the cursor.
Here are the step by step procedure of selecting a cursor:-
The cursor has been saved and then next time it won't change.
Good Evening,
Having animation cursors is really cool and I always change my cursors to animation. However, I also run into the same problem. I have to tell you, it’s a pain in the neck. I just can’t it when that happens. When Anyway, you want to stop the animation from changing. Here’s what you need to do:
Hope this helps and Good Luck.
