giddeo 20 points N/APosted on - 08/14/2011
Hi,i have an interesting question. My question is that, It bothers too much, to adjust the wired speakers with PC. This problem can be solved by manufacturing wireless speakers. So that one could put them anywhere in the room. Wireless Speaker should have such a mechanism that it could be attached with any type of computer. It will be enjoyable when,no one could judge where the music is playing from.
Well, actually wireless speakers is already been manufactured and also available in the market. Wireless speakers are actually has two units, the main speaker combining the loud speakers itself with an RF receiver and RF transmitter, these transmitter will connect the audio output in any audio devices like hi-fi equipment as well as computers also in mp3players.
This frequency ranges up 900MHZ, This Radio Frequency signals can pass through walls and ceilings and transmits to a range of 150 to 300 ft. A lot of wireless speakersfeatures changeable transmission frequencies it can be set in a tuning know to overcome RF interference with other close by devices such as cordless phones and monitors.
Although wireless speakers are already in market but i will not prefer some wireless technology for your system. Because of these reasons.
It may not work at a distance of more then some meters.
It will be a costly technology.
Wireless signals contain noise when passing through air and which can infect the signal quality.
It can contain more noise then voice.
It will not work if there is no light plug for speaker phone near to your desired location for speakers.
I think these are the reasons that wireless speakers are not so common now a days but in feature may be they will be easily available because scientists and engineers are all the way working to reduce the noise quality in signals when passing through air and that's the reason it may be available in near feature but not sure about it.
Yes, there are wireless speakers now already available in the market and you can use them both on desktop computers or laptops and Smartphones. Since it is wireless, it can easily be paired with another wireless device like with a laptop and a Smartphone via Bluetooth. Check out the following wireless speakers:
GOgroove BassPULSE Bluetooth speakers
GOgroove BassPULSE Bluetooth 2.1 Computer Speakers – audio input supports Bluetooth 2.1 and 3.5-millimeter audio port. This is good for desktop computers, laptops, Smartphones, tablets, and MP3 players. For desktop computers, you might need to buy a separate Bluetooth receiver because the package doesn’t seem to include a Bluetooth adapter. This costs $59.99.
Boytone BT-209FB, Ultra Wireless Bluetooth – speaker system supports both wired and wireless connection via Bluetooth. Total power output is 30 watts for the subwoofer and satellite speakers. Requires 110V AC. Costs $57.99 with 1-year direct Boytone USA warranty.
1....
