Have you used SMS Popup source code?
I found an article saying it was released a few years back. Has anyone of you used the SMS Popup source code? Was it useful?
Thanks in advance.
Thanks in advance.
I have used the SMS Popup and it was very useful. Some of its features are listed below:
1. When you get a message you get the name, picture of the sender and the content of the message. This makes it easier to check messages as you do not have to unlock the phone and go to the inbox folder repeatedly. This saves a lot of time and effort. See the screenshot below:
2. You can also reply to the messages on the screen directly without going to the inbox. It is very tiring to go to the inbox repeatedly to check and reply messages if you message frequently. So you can use this to minimize effort and reply instantly.
3. You can also change the led light according to the contacts and you can also add a special ringtone for each contact. The latest version has a lot of features compared to the older versions.
