Having difficulty with on Linux OS on my Remote Desktop
Posted on - 01/16/2012
I am having difficulty with on Linux OS on my Remote Desktop. Whenever I type ‘krdc’ in the terminal, then a windows is appeared where I give my patch with VNC:/{IP ADD} also RDP:/{IP ADD} . After that, there is error showed that desktop isn’t installed. I am not able to install desktop using YUM. Another thing is, can I share desktop and use remote desktop when I have Linux and Win XP on the other .
