Having a ecommerce onlineshop system website or software
I'm a busy person and i don't have the time to go to shopping malls or marts so i mostly shop online. It would be a great help if someone can help me find  a software or make a website which has a good ecommerce online shop system. How does this work?
Best Answer by Mclean Buono
Answered By 60 points N/A #157498
Hi Marie,
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to having a ecommerce online shop system website or software.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forums, which are listed below
1. https://www.shopify.com/tour/ecommerce-website
2. https://www.ekm.com/
Answered By 10 points N/A #157499
Hello Marie,
There are many software which can help create online shopping websites.
You can have a look at these –
  1. Magento Community Edition – Possibly the most widely used e-commerce engine, it can be easily customized. Catalog and pricing are easy to manage and setup. Its is PHP based application.
  2. PrestaShop – Relatively new entrant, but has gained lots of popularity of late. It offers integrated shipping, analytics, checkout and much more. Its is PHP based application.
  3. Bigcommerce – There are lots of available templates and you can quickly setup your website on it.
For all the above, you may need to hire a developer or designer to design the website for you.
Hope this helps you make an informed decision.
Mclean Buono
