Hi there,
I am relatively new to the world of SEO and for my first attempt, I have been recommended to use the autolinkspro script. Can anyone please guide me on how to apply or use this script.
Is this script meant to be run on a browser or another native application?.
Thank you
Having installation problems with autolinkspro
AutoLinksProis designed to helps you automate links exchange process. AutoLinksProuses mod-rewrite for creating search engine friendly url and the link directory support sub directories.
Covering all the feature of AutoLinksPro would actually make a big post.
Please visit for more detailed features and script usage.
The actual cost of the script is around $70 dollars and if you want it installed then its $90.
Highly recommended if you can get it working for your server/machine.
HTH!
