iRandom
Posted on - 01/12/2012
Any suggestions so that this PCI works well to my computer? I am running Windows XP. And I’m having an IRQ conflicts with the USB adapter. I want to change the D-Link WDA-23320 wireless PCI adapter because It having a conflicts. I already tried to install it and it went fine and after for a while it already stops working.
Having an IRQ conflicts with the USB adapter
The error you are getting is possibly being caused by an issue with the driver, and therefore you will need to go to the device manager and see if you might have installed the wrong drivers for the USB adapter and the wireless network. It may also be possible that it is a power issue with your USB hardware. The USB devices are sometimes powered by the USB hardware on your computer, or they can be alternatively powered by an external USB hub.
In that case, it will be possible that the USB ports are overloaded in case there are too many devices that are plugged in and drawing more power than your computer has been designed to supply.
-Richard Gabriel
