Having a issue with right click
Hello guys,
My Google chrome suddenly freezes when I am trying to right click on web page, please help me to resolve this problem, I have reinstalled the program, but I didn't succeeded.
Hello guys,
I will give you possible solutions for your problem:
1. Please update your antivirus and have a full system scan (You must have a Good and trusted antivirus I recommend using kaspersky and Norton).
2. Have a registry cleaner and fixer (I will give you a link on the program that I am using http://www.piriform.com/ccleaner/download). Please download and install the program and Run it. Click on the registry and scan for issues and it will fix it.
3. If still the error occurs try upgrading your RAM or have a flashdrive that is 4 GB or 8 GB and use it on readyboost (for Windows 7).
If you still have the installer, try reinstalling Google Chrome. Download and install Revo Uninstaller Free. Once installed, start Revo then select Google Chrome among the applications. Click “Uninstall” then follow the instructions to completely remove everything the program created on your computer. After this, run the installer to install Google Chrome back then see if it works.
If this doesn’t fix it, try updating to the latest version. Download Google Chrome from the official website or from FileHippo: Google Chrome. The latest version at the moment is Google Chrome 58.0.3029.110 and it supports Windows 7, Windows 8.x, and Windows 10. It dropped support for Windows XP and Windows Vista in 2016.
If this doesn’t work either, try using other web browsers like Mozilla Firefox, Safari, and the Opera browser.
