Hello, I use windows 7 on my laptop. I have four SD card readers and all of them got damaged while using on Win 7. I am not sure if it helps, every time when I try to eject the card the Led Indicator of the card reader doesn’t go off. Please suggest, how to solve this problem?
Having Issues with SD card reader on windows 7
Hi Jolene B
This might be caused by a lot of different issues.
Firstly you need to ensure that before ejecting the card no program is running with the card. Shut all before ejecting.
Secondly make sure there is no virus in the card or your computer. Some viruses may seriously cause this problem you are facing. Check for viruses by get a new updated antivirus the scan your computer and if possible get new windows 7 system installed and try again.
Thirdly you can check to ensure your computer ports function properly. Â
