Having problem with android system
I am facing some trouble with the android system of my android tablet pc. The touch screen is not working. I am in some serious predicament. I have already tried restarting it but still the same. What could have cause this problem? Should someone know of this problem kindly inform me.
Arturo Owen
Answered By 5 points N/A #108098
Did you try switching your system off  completely and then switching it on again. Many times this does work.
Best way is to Try and get an Update for your system. That should help you to get the latest fixes and thereby solve this touchscreen issue.
You can alternatively ,Download software called xFlytouch256 from the internet and install it in the system. Along with it find 2.0.1_88_rooted_market_apple.rar file and install the same.
This should solve the issue
Answered By 590495 points N/A #309843
If your Android phone has a problem with the touchscreen function, try factory reset. If your phone is running on Android 4.4.2 KitKat, go to “Apps”, “Settings” then “Backup & reset”. Make sure “Back up my data” and “Automatic Restore” are unchecked to perform a full reset. Under “Personal Data”, tap “Factory data reset” then “Reset phone”.
Before factory resetting your device, back up all your data to your memory card and your contacts to your SIM card then remove the memory card and the SIM card from the device. If your phone is running on Android 4.0 Ice Cream Sandwich, go to “Settings”, “Storage”, “Factory data reset”, “Reset Phone”, and then “Erase Everything”.
Your device will then perform a little housekeeping and wait until it is complete.
