Having a problem getting web site built
I am having a problem getting web site built, I am not used to any scripts or languages to create a website of my own, so I need to have few online providers who will have their own templates that is user friendly to edit and can have the web page launched with lowest price.
Answered By 0 points N/A #157415
Hi Morison,
I have been using languages and some software to create a website for myself. And I have also tried some website builder sites. I came across also with some free website builder.
One I can recommend which I think really is for beginner is Yola. I attached the link on the name itself.
It is free however if you want to upgrade features they have packages that is not really that expensive like upgrading storage, use or add domains and lots of better features than any other website builder sites.
You can try to check their DEMO if it suites you best.
Hope this helps.
Answered By 590495 points N/A #311130
If you want to use a template for your website, the best there is in creating a template is to use Artisteer. With this application, you can create your own template without paying somebody to create a template for you or instead of using a pre-made template. To try it, you can download the free trial from Artisteer Web Design Software.
Aside from creating a static HTML template, you can also export your designed template to WordPress, Joomla, Drupal, DotNetNuke, and Blogger. The latest version at the moment, Artisteer 4.3, supports Windows XP, Windows Vista, Windows 7, and Windows 8. It requires 1500 MHz Intel or equivalent AMD or faster processor, 1 GB RAM, 150 MB free space, and Microsoft .NET Framework 3.5.
If you don’t have .NET Framework 3.5 yet, download Microsoft .NET Framework 3.5 Service Pack 1. Artisteer supports the following web browsers: Microsoft Internet Explorer 9 and higher, Mozilla Firefox 4 and up, Opera 12.6 and up, Apple Safari 4 and up, and Google Chrome 10 and higher. Artisteer supports the following standards: HTML5, CSS3, Section 508 (partially), and PNG with transparency.
For the pricing, go to Artisteer Purchase. Artisteer is a WYSIWYG website theme creation application developed by Extensoft. It automates creating web templates like with the “Suggest Design” button which randomly generates design and displays the design preview. The trial version has no time restrictions. You can use it as long as you want. You just can’t save your design but you can do all the exports.
