Having problem with Lenovo G580 laptop
I am using Lenovo G580 laptop and I am unable to open my drive D; whenever I try to open drive D, I get this message "D: is not accessible. Access denied" Is there anyone experiencing the same problem? I can access all other drives but not drive D, Kindly help me?
Answered By 0 points N/A #180744
The message you are getting is not a rare one. It happens sometimes to your system and also it is not the fault in any make of laptops. The error is because your access is denied to the particular drive. If any error like this happens you will not be able to access the files in that drive, if you want to get your files back, then you must restore your system with a backup.
“How to fix this error and recover data” is explained in this link for windows 7, vista, or windows XP.
Click here.
