wirt yule
50 points
Posted on - 02/11/2013
I recently downloaded a video in avi format. When I play the video on VLC Media Player Version 2.0.5, it says "You need to install LogMeIn video decoder". I already have logmein installed. It has audio but no video. I need help in logmein avi codec windows 7 x64.
Having problem with Logmein avi codec Windows 7 x64
Hi Wirt,
You have to download ffdshow CODEC plugin for your video player. After download installs it & configure it for avi. Usually avi files are playable in VLC but some avi files need to configure ffdshow CODEC to play. There is an image,
Go to avi format & make the decoder as libavcodec. I think this can solve your problem. Oh here is the link to download ffdshow. Hope this would solve your problem. Thank you.
