Hello Techyv users,
I am using perl panel windows version on my Windows XP system for a long time. My perl panel not working from the last time I had scanned my system through antivirus software. Please help me out. It is affecting my work badly.
Having Problem in perl panel Windows XP interface
Hello Johnny.
It is possible that after the antivirus scan your antivirus software has removed some files in Perl Panel installation.
You can check the antivirus software log, It'll show whether it has deleted those files or not.
If deleted sometimes files can be still in the quarantine where you can recover them.
If this fails you can download Perl Panel from here and repair your current installation.
