Having problem in running MSE
Hello Everyone,
I am using MSE alone as the protection. I am having problem in running MSE. Whenever I try to turn on my system, it appears with the message in the windows “Microsoft security client error", the code is 0x80070020 and its icon is also missing in the system.
Same error code appeared when making an attempt to re-install or upgrade it. Further, I am using a new internet connection; I just thought that it might be causing trouble with MSE.
Can someone please help me in fixing this error?
Thanks in Advance.
Answered By 95 points N/A #159758
Sometimes MSE create some problem to running.
You have to follow the total instruction here I discuss.
At firs you have to verified this action-
1.you have removed all other real-time antimalware products which were ever installed on your Computer.
2.It also include trial products that were installed when the PC you purchased (Norton, McAfee, TM, AVG, OneCare, Malwarebytes (paid), etc).
3. After verifying, you must clean up those of anti malware program. Visit the site for clean up tools
After when you have done the process reinstall MSE, probably it will not shown the error code further.
If you want to make sure about remove all selected program, then visit the site for scanning
For a detail process and more options to fix your problem perfectly visit the site
Hope you will get resolved.
