XpertIT
40 points
Posted on - 03/14/2012
What if one have checked already his start / power button and found that it wasn't really its start/ power button that has problem.
The computer fails to turn on, what part of the computer has the problem? is it the motherboard? or the power supply?
Having problem on the start button/ power
Hey Xpert iT!
If you are having the problem that your Computer is not starting and you are sure that the power button of your computer system is fine and still your computer system is not started, then I recommend you to check your power supply. There is also a possibility that the power cable of your Computer system is not working.
So first make sure that your power cable is working fine or not. If it’s working fine then you need to check whether your Power supply is working fine or not.
It’s not the problem of your motherboard. Computer must start and show some display if it was the problem of your motherboard.
Thanks
