Having problem with WinZip shell commands within excel
HI,
I use windows 7 on my PC. I'm having problem with winzip shell commands within excel. I would like to get help with this. Please anybody step ahead to help me immediately.Â
Thanks
HI,
Thanks
Try swing a group of quotes on the correct facet of .Ex
\"C:\\Program Files\\Winzip\\wzzip.exe\"
It would look like:
lngProID = Shell(\"C:\\Program Files\\Winzip\\wzzip.exe\" & \"-v \" & \"C:\\Temp\\Junk.zip > C:\\Temp\\List.txt\")
I am within the middle of doing one thing terribly similar.
Hope this helps!
Try running the command directly within the electronic communication. I.e. begin > Run > cmd.exe
Then kind in your example i.e.
This should show you if the procedure is fortunate.
